Got an extra bed last weekend
94 lngbd
15+ Year Member
Lakewood,Wa
Its a 6ft as mines a 7ft ,but I have already removed front panel from bed & about a 8.5x9 cut out surrounding the fuel door.
My Front panel is damaged a small amount ,but I wanted to try out the new spot weld cutter so I removed from donor bed & will be going onto mine when I get around to taking bed off.
Im also going to be cutting up some sections of the side panel upper section to use for bracing as Im planning to make side pockets on both side similiar to the new Dodge trucks ,but mine will hinge down not up due to me having a ladder rack & Canopy.
I already cut the 8.5x9 section out of the rear area of my 7ft bed to make a rear fuel door for future project of 20 gal aft axle fuel tank. I got 4 strips from donor bed floor cut & spot welded to opening for extra support flange for the new fuel door section to be spot weld to before butt welding the entire cut out opening.
Was hoping to get it all welded in today ,but that damn Rain came & no room in Garage ,but there will be with in the next month.
