got a quote on the damage
hah nice band aid
and my old man is the same way no motivation any more, but on the bright side he'll drop his truck off and his bank card and tell me to fix it...
I need one of those for the chevy. I bumped it with the clothes basket and dented it.
You go off-roading, exspect damages to be done.
Yes, insurance is great. But full coverage is not worth it when your truck is worth less than 3 grand. Insurance will just write it off before fixing it. Besides, the body is only there to protect what matters the most on the inside.
What happened to your bedside? That quote really doesn't seem too bad. Replace the whole bed panel, tail light and paint it to match. Red is also the most expensive color to buy.
As far as the OP goes...
That sounds about right. Might be a little high, but it sounds about right for a professional job. Basically, that is a difficult area to work on and it looks like some of the metal is creased a bit. Sure you could whack it with a hammer and 2x4 a couple times and smear some bondo over it to make it look close to stock, but to actually work out the wrinkles, skim over the rough spots, sand it, and paint the entire bedside (anything less will be noticeable where the fresh paint stops), theres probably a good couple days of work there.
Of course, if you don't care about it all that much, you could bang some of it out yourself and rattlecan some paint on...
Or look for a junkyard truck the same color with a good bed.
