All is dry now. But, it was driving me crazy.
First, I flushed out the cowl by removing the access plates and putting a hose in there. Didn't seem to be leaking from inside there. But, a bunch of dirt came out.
1. Found a leak in the pinch seam on the left side of the firewall. Just below the cowl access panel and to the right of the of the wiring harness. leaked into the cab where the left cab panel and the firewall meet and ran down the corner seam. Cleaned the seam and used rust converter on the rust. Then resealed that. Probably would not have leaked if #2 had not rusted the seam and pushed the caulk out. I had to tear out the interior sound padding to open up the area.
2. The hood/cowl gasket was leaking onto the top of the power brake booster and onto the firewall in a number of places. Replaced the gasket and put butyl rubber sealer under it when I installed it. Actually, I got another one from the JY (free) and made a longer one from the two. So that it would go all the way across to the fenders. That fixed that leak. Also sealed around the brake booster and steering shaft because I could.
3. Windshield was leaking. Found that by foaming the outside of the windshield and blowing compressed air around the edges from the inside. It was the original windshield and had seen better days, so had that replaced. That was the worst because of the cost ($160). They found rust on its frame and it had creeped under the original seal (treated that with rust converter). Sort of weird, because the leak was showing up inline with the steering shaft; but, was actually about three inches up the left pillar.
I was lucky that there was no rust (well very little and I treated that) on the floor pans. When I put the interior back in I sealed all bolts and screws as they went in.
It took a lot of time, money and effort; but, I think it was worth it.
Ed
