Your truck is going to feel lazy after swapping those tires. You are giving the enemy a 10% advantage against your engine. You counter it by installing a 10% deeper gear. That's basically 1 step in gearing. If you have a 3.45, go to a 3.73.
I would keep the stock tires. That 10% disadvantage will cost you at the pump. Your motor will work 10% harder anytime you accelerate (going up a hill while maintaining a constant speed is accelerating). That acceleration uses fuel.
You are throwing away 10% of your torque by switching tires. That also accelerates clutch wear. The expense of the the tires and rims must be considered, especially since smaller tires are cheaper.
Those are the debits. Now let's see the credits:
Little bit bigger tires and new rims.
The credits end quickly. The debits keep on biting long after your tires and rims feel new, big and wonderful.
