How much of a difference did it make in your mpg?
1 or 2 mpg on my Ranger, depending how much I had my foot into it.
Just want to clear the air for the guys that didn't understand what I was trying to say... (I could be wrong though)
It's simple aerodynamics... a soft surface that is allowed to flex against wind resistance will absorb energy, transferring it to your truck and therefore increase drag rather than a hard surface that doesn't yield. Next, your AC doesn't only cycle in "defrost", it cycles the entire time it's being used, I'll go plug mine in and take a video to prove it to you if you're having trouble understanding that.
4x4's have extra weight/shit which some parts are always turning or engaged rather than a 2WD, that's what I meant about "linkage" (front axle, hubs, transfer case). From what I've seen, a 5spd should kill a automatic transmission in mpg, so getting a 4x4 with an auto transmission just sucks if you expect to get "better" mpg.
As for tires, mine are WEATHERED 31x10.5 all terrains (Not small tires) and like I said... weathered tires tend to have weak side walls witch makes them sag, creating a larger surface for you vehicle to push... push a 20lbs ball down the street along side a 20lbs bag of sand, see what I'm say
...Obviously the compressor moves when you have the ac on! We were talking about using the heat, it will turn on when its in the defrost mode. It will not turn the compressor when its on the floor mode or vent.
...But the only thing extra that turns when you have manual hubs on a 4x4 ranger is the transfer case, the drive shafts and axles stay still while in 2wd...
Some people don't like this, but I always unplug the A/C compressor in the winter. I've never had any adverse effects from doing so either. Turning that pig eats gas, and if it's not changing my climate, then I'd rather not be turning it.
I've done it on my Mustang, Explorer, Mountaineer, and Ranger. I have not done it on the Escape though. The F150 is getting it this year.
For a 1mpg difference, I'll leave my AC hooked up and the control in Vent mode if I don't want AC. I rarely use Heat,or Mix, and only use Defrost when the windshield is fogging up.
The compressor runs when on all settings except just floor or just dash if I recall correctly. If you are on floor and dash or any of the ones that include defrost, it runs the compressor. I'd have to go out and check to be 100% sure, but I seem to remember that's what I had figured out when I got the truck 2 years ago.
As for the 4wd I don't know about other newer Rangers, but my 2000 has full-time locked hubs. Not pulse activated, not manual, just solid. So when I disengage my 4wd, it is still turning the axles and it just disconnects at the t-case. That said, from my research this only brings me down about 1 mpg on the highway and not noticeable in the city, so I'm ok with that.
Omg, I feel like punching my self int the head repeatedly! Ac on, the compressor will run, defrost compressor will run, the only other settings are vent(dash) and floor r both of them combined, I should have to say that! Do I have to repeat myself again? Floor and dash does not run the compressor!
I honestly thought it ran with it set to floor + dash. That said, I'm too lazy to go outside and check, and since it doesn't really matter, I'll go with your word on it.
defrost-runs
dash only-off
floor only-off
floor dash-runs
floor defrost-runs
defrost-runs
dash only-off
floor only-off
floor dash-runs
floor defrost-runs
i know becasue the ac pump is attached to the low speed on my E-fan, and i can hear when it comes on.
with that cleared up, lets focus on things like airflow, engine efficiency and fuel types.
No, the hamburger you just had for lunch wont cost you 1mpg, but your heavy foot will.
simple rules:
reduce drag/friction ~ wash your truck, grease things, change fluids, close up gaps that cause drag, check tire preasure, check bearings, brake drag.
reduce weight ~ clean out your truck, remove spare tire, use lightweight tonneau.
reduce consumption ~ give it less gas to start, stop slower, drive like you 95 and a cops riding your ass (awesome way to not get tickets and great MPG ~ WIN/WIN), allow more air into the engine, reduce the work the engine has to do to move air out.
stop putting 35's on your trucks factory gearing and saying
stop racing civics (#1 MPG problem)
and for goodness sake, stop complaining.
Sounds like you know what your talking about. I'll take your advice.
