full width sas
Really guy? I'm going to have to ask the same question as 86, did you pass the 5th grade?
Trying to sift through your incohearent, poor grammatical posts is like trying to have my dog tell me it has to poop! I'm sorry everyone is coming down so hard on you about your ideas, but for god sakes, use the spell check option up in the top right corner of the box when you post!
Other than that uhhh..... Most of the info in the tech library and in other posts whether it be for full width or stock width is pretty much transferable to whatever project your doing, you just have to stop for a minute and think about the principles behind what they're doing, and apply it to your own project. Comprende?:icon_thumby:
ah yea first off welding spring steel equals bad as you have learned.
secong why not post up some pics of your build on here
third heres some links to my swap. i made my own radius arm mounts. they hang down pretty low but i used 5.5 inch coils so the trucks is pretty tall and without extended arms they have to be low to get the right caster without cutting the c's and rewelding.
back in the day of ttb i modded my stuck coil buckets to except a longer shock. i am using ford escape rear shocks up front they work great.
http://rrorc.com/forums/showthread.php?t=37678
http://www.therangerstation.com/forums/showthread.php?t=26697
hope you can get some info from this
