- Sep 23, 2007
- Manual
I got lucky this weekend on a trip to the junkyard. I found a '92 4-banger Ranger with the bed pulled off and the tranny removed. It was trivial to pull the whole high pressure fuel line setup from the tank to the motor.
Since I had gone to the boneyard for sheet metal, I did not have metric sockets with me to pull the fuel rail (doh!) and had to hacksaw the lines upstream of the coupling and downstream of the rail.
Since my truck is an '83, I now have no idea which line goes where on the fuel rail. I do have an EFI tank and pump/sender from an '87.
Obviously the line with the fuel filter will be the supply line at the tank. Which port on the rail should it be hooked to?
Also, will the stock EFI Ranger fuel filter flow enough for a Walbro pump and the 2.3T, or should I be looking for something different?
I'm doing bodywork and paint on the truck now, but should be able to mock up the 2.3T indoors and get it started and running before the weather gets lousy this fall. I'll worry about swapping it in once I see it run.
Thanks!
Thanks!
