Fuel Smell
Gainesville
FL - USA
I’m getting a really strong smell of raw gas when my 1990 ranger is running.
I can’t see any leaks where gas is dripping from, so what do you think would be causing such a strong fuel vapor smell?
I already replaced the gas cap and that did nothing…
Should I get a smoke tester to track down any leaks?
Any advice is greatly appreciated!!
Is it just running that rich? Any exhaust smoke?
I do see thin white smoke on startup, but it goes away after a few minutes. No black or dark smoke. It
It smells like it’s coming from the engine bay and the exhaust. Just crawled under it with it running and still no signs of a visible leak…
So, I had a raw gas smell around my Choptop, finally found that the fuel lines had 7-8 pinholes all through it, it would weep just slightly under running pressure and just bleed pressure down after it was shut off. I put all new fuel lines on. No more problems.
Event Coverage
TRS Merch
