Use a Fuel Pressure regulator(FPR) with return line
Same as fuel injection uses but for a carb you need an FPR that can be adjusted down to under 10PSI, 6-9psi is spec for most carb engines
After 1988, Rangers had electric fuel pumps capable of 80+ PSI, FPRs were used to lower that down to 35psi, the rest of the fuel/pressure was sent back to the gas tank on a Return line
In 1998 FPR was changed to 60psi but still an FPR to limit pressure at the injectors
Your 1993 will have a IN from pump fuel line, and a RETURN fuel line in the engine bay, you can use both on a different FPR, one made for carburetor use
