Someone help me out here.... 88 2.3 manual.
The red wire on the fuel pump relay is the trigger (12v) to close the relay and send power to the pump. I can't reliably get 12v on that wire. I poked a jumper into the relay, relay close, pump came on. I checked and found fuel at the fuel rail. Pulled the jumper off, and the relay stayed closed. Checked again... and NOW had 12v on the trigger wire..
Turned the ignition off. Turned it back on. Right back where I was. No power (actually, 1-2mv, but not the 12v needed).
I'm guessing that the computer will be the source of the 12v power to trigger the relay. Any way I can possibly fix this without hunting for another computer?
