Fuel Pump Problem
Well, tried to start it up today, it took 4 clicks on the key to get the pump to work. I'll have to do some investigating...
Everyone tells me that it might be a funky ignition switch. But i'll run some tests and see what's up. I suppose
Get a test light and see if you have power at the fuel pumps. Note however that you will see NOTHING unless you ground out one of the pins on the ECM test connector. I forget which one.
