- Mar 4, 2012
I have a problem with my 2000 Mazda B2500, where it seems like the fuel pump doesn't turn on sometimes (possibly due to the cold weather). I swapped out the relay for a different one and that did not make a difference. I also checked the inertia switch, and it was fine. I used a DMM to figure out how much current the pump was pulling and it was pulling 15A (way over the 10A limit) and was wondering if its too high. I think it's due to the fuel pump seizing and not being able to turn over in low battery voltage, since sometimes if a battery charger is hooked up, the fuel pump will turn on and I will be able to start the truck. Once it has warmed up though, I have no trouble starting it back up.
I just wanted to check for any other suggestions before pulling the fuel tank and replacing the pump.
