fuel pressure regulator
skyy_4life
Boosted (Not Stock)
Brooklyn Ohio
hey guys my turbo came with a adjustable fuel pressure regulator, i was wondering how would i remove mine and put the adjustable one on. it is one that connects to the fuel line, would i just unhook the vacuum from the stock one and put it to new one? the fuel pressure regulator is the one all the way to the right.... any suggestions.
Will that even bolt to the factory Ranger fuel rail? If it does, all you have to do is unbolt the old one and bolt on the adjustable one. I'm not why you would need one as the factory Ranger regulator is a rising rate regulator whick will raise the fuel pressure under boost. My regulator runs at 50 psi at 5spi boost, which is more then enough for what you would need.
