Fuel injectors were not the remedy, sadly
Nope, once the body was on we had an alternator fail and the starter relay. Got those sorted out now dealing with all this.I'm not sure exactly how the ECM is protected or not protected, so it is possible that the battery connection backwards could have damaged it.
I also think a 2.3 wiring harness would certainly be much different than a 2.9 harness. The ECM is of course in the cab, and would require different signals from different parts of the engine and the 2.3 harness may not have those wires, or not where they are supposed to be connected, so that may be quite possible that the harness needs replaced.
Did this truck ever run correctly after the body swap?
My upper intake definitely was covered in a layer of carbonI don't think they're in play here unless your intakes are sh*tted up.
That's why I was wary of all the 'refurbished' fuel injectors on Ebay and Amazon. I think once the IAC and TPS are replaced it will be much easier to determine if the computer has a problemSo, without a rotunda tool, EEC-IV ECMs are difficult to test. Yes, you can sit with a volt meter and test each I/O connection. However, the safest way is to look around under the capacitors for a leak. When an electrolytic capacitor dies, it usually poops itself all over the board under it.
Sometimes they only poo a bit, other times there's no poo. If you have a capacirence meter, you can check them individually. However, much easier to get on Mouser or Digi-Key and order the same as whats in there. Usually, this is all a "refurbished" ECM is - A junkyard pull thats been repainted, had a new sticker slapped on the case, and new capacitors (sometimes).
Sometimes the only thing new is the box.
