fuel injectors
remington115
are the fuel injectors in a 96 2.3l smaller than the ones in a 2001 2.5l. my trucks running lean i just swapped a 2001 2.5l in my 96 but i am using the 2.3l fuel injectors. also its has a miss fire in cylinder 1 HELP!!
Are they the same color?We put yellow tops or red tops in our race truck with good results.I know some guys on here say no difference in performance but dyno says different.sometimes when you change engines,you bump a fuel line after the filter and something can get in the line and get to the injector and partially plug it.I would change that one injector with your other one,same color and top hookup,right?
i just found out that the ones in my truck are the 2001 so they should work and i just put new plug wires in still running the same lean. i am running the 96 computer i tryed running the 01 computer but it runs like shit, so im sticking to the 96 computer ans the 96 wiring harrness
so update. some times it idles fine sometimes there is a missfire could it be sticky valves
It could be a sticky valve,especially in a 2.5 because they have such a small spring.Put a little Marvel Mystery oil in it,that will help if its sticky.You hooked up all the grounds and sensors?Did you have the intake manifold off?Check for a air leak?Did you use the 96 intake or the 2.5?Did your 96 have a return line and the 2.5 doesn't?
were do i get marvel mystery oil and how do i put it in. all grounds hooked up. i did have the 2.5l intake manifold but i did take it off, but the gasket was like new. checked for a leak by spraying carb cleaner around the intake manifold it didnt rev up so i guess there is no leak. im thinking there is a vacume leak but cant find it. there is a strange sound coming from the back of the engine by the egr but i think the egr is good also put a new egr gasket on. i just cant find the problem. scanned it at a friends shop and now it says there is a random misfire and its still lean
You can get Marvel at any Carquest or Napa but the way you just explained,I think you have a air leak some wheres in the intake.Aren't there a couple vacuum hoses under the manifold?Did the 2.5 have the same return lines as the 2.3?Some of the 2.3 had a single line and some had double.Better pull the intake and at least use some silicone spray on the gasket if you don't replace them.
update i found a problem, one of my spark plugs was striped i thought that there was a vacume leak but it was the plugletting air in and out, its weird because the head didn't strip, but i put a different plug in and it tightened down and was not crossthreaded but its still missfireing and lean. also sometime the truck revs up to 2000rpm and stays there until i shut the truck off and then on, Then it idles back down
put new plugs in it. better but still a little rough idle
I know the feeling, mine runs like poo too, worse under boost so it's kinda boring...
i think i found the problem i think its the TPS some times it will idle up and stay around 1500rpm-2000rpm then i shut down the truck and turn it back on it idles down. could this cause a lean condition and a small misfire a bad TPS
o well i got a extra one so ill throw it on and let you know
it was the plugs after a little bit it started to idle good but as for the TPS i tested it and it seems fine and stoped reving up but does it every once in a while
