- Oct 9, 2007
- Age
- 37
- Fleetwood PA
- Automatic
Alright, as of right now my truck is has a carb'd 302, 1966 block non roller motor in it. I just bought a 1988 thunderbird 5.0 non HO (thought it was) for $500. All i bought the thunderbird for was the fuel injection, because i want to turbo my truck and want the tuneablity. Now If im right, the tbirds fuel injection should bolt right up and work fine with my truck, but you cant get all those fancy computers for the non-ho(right?). So my question is will a 5.0HO(like a fox body mustang computer) work with this set-up or will it screw with my firing order. and if it does mess with my firing order, can I just switch the injector wire's & spark plug wires ( so that it would fire as it was a ho but i would have the injectors and wires switched up so it would actually fire in the non-ho order) I can clear this up if i wasnt clear enough... hard to explain
