front wheel hubs bearings keep goin bad
mclarenf1gtrv12
20+ Year Member
cali
ok ive replaced both front hubs and now my passenger side front bearing is goin out again i took the hub lock cap off and there was dirt insode so i cleaned it out hopin it would be fine but now i can hear that whining roaring sound from my wheel bearing slowly getting worse and worse until it fails completely what can i do about this is how is this not a common issue im seeing on here i have a 2000 b3000 wit the shity vacuum hubs im changin those out for the avm's manuals but that still wont help my bearing problem is there like a explorer hub and other parts that will fit my truck and not give me this issue
Most premature bearing failures are due to incorrect preload when they are installed.
I have a ranger Im about to do the wheel bearings on, It requires different grease than 2wd due to the possible higher temps, but if you use the valvoline syntheitic or semi synthetic grease you shouldnt have a problem. i would pull all the parts clean it with diesel to get ALL the dirt out and make sure to properly repack the bearings.
My only question is what is preload? I assumed the bearing were 'pressed' into place on installment and everything went back to gether, I dont see hwere its adjustable.
Unit type bearings are pressed together but there is usually something that keeps them together when they are installed (shaft for instance) and whatever holds them together has a torque figure that is very important, too tight and the bearings are damaged immediately, too loose and the bearing will eventually work its way slightly apart and fail later. Torque figures are published for a reason, not just to keep some of us entertained for a while.
