front end alignment
1986b2
10+ Year Member
are the factory alignment bushings in a 86 B II 4x4 ajustable ? please help asap
thanks yall i will have to buy new ones and do u know what kind is the cheapest just for my washer lift?
I've never seen stock adjustable. Got mine from napa in stock for right around 75. they were 3 1/8. good to get the biggest they sell just in case you put a lift later and still have a lot of room for adjustment.
My 93 dana 35 stock bushings are adjustable, but the old dana 28 I had in my BII was just a straight hole and it was centered in the bushing IIRC. I bought heavy duty 1-2" lifting springs that came with the bushings from JC whitney for $180, or you can just get bushings ordered from NAPA or ebay or something.....ive seen them as low as $35 i think.
i used moog k80153 on my 85, i put them in backwards(3.25* postive, 2.75 neg), i was worried about them not adjusting enough so i put them so i could get 3.25* neg, set them all the way neg. that way i can fine tune with my eccentric cam bolts on my drop brackets which were all the way neg. that way i could have some room to play with, and the alignment shop only has to mess with the cam bolts on the pivots
