- May 4, 2009
- San Diego, CA
- Automatic
I have a 2001 Ford Ranger XLT 4x4. I've repeatedly changed my front pads and rotors time and time again for years. And this time, at one point, I accidentally failed to easily push down the two pistons on one of the calipers. So stupidly, I pushed one all the way down and the other fully extended. At that point it was difficult to push back down. I removed the caliper and was able to remove the piston. Drained out the fluid and then noticed nothing preventing the piston from sliding in. I figure by having the caliper off the break line I'll be able to put both pistons back in evenly. And I did. I put the caliper back on. I refilled the reservoir and was able to finish off the break job. I pump the brakes and I can feel the tension return to the peddle. It feels normal. But once I turn the key the pedal becomes extremely soft and I have to push it all the way to the floor to break. At that point I realized only the rear brakes are catching. Was it wrong to remove the break pistons and re-seat them? What else could be causing the breaks not work when I turn the key and start the car? I tried to bleed the brakes but who ever owned this truck before, striped the bleed valve. I noticed that new calipers aren't too costly and I was thinking it would be easier to replace the calipers. Or, I can just go to a break shop and ask them to bleed the brakes quickly. What would you do? Thanks for your help.
