Frond End Shakeing Badly!!
Sounds like a caster problem to me, get your alignment checked out.
my truck did the samething....it was a shock
^^^now thats a new one....... mine are prob really warn out......
Also are u running 4" coils? Cuz I might use the axle pivot hole on top not the bottom one.
Yes i have a drop pitman arm......
and yes im running 4in coils, explain what you mean by the axle pivot hole please?
you jacked up both sides and checked for loose balljoints,spindles/bearings and radius arms/bracket mounts and found nothing wrong?
i would think it was actually a visible loose bracket from that description:not_i:
or the spindles are backing off and the clip and thrusts are holding on for dear life.... seen that too many times....pull the lockouts and have a good gawk at the situation.
