Frnt 1/2 shaft seals
BiggSherm1988
Forum Member
U.S. Military - Active
Germany
none...yet
Total Drop
not for me
I am replacing my front axles and I wanted to get the seals. On rock auto it doesn't list both, just one side. Are they the same? Does anyone have some part numbers?
2008 sport
Just so you know you aren't being ignored. I don't know the answer but someone should. Good luck!
they are different, I may have the Ford #s in the basement. with those you may be able to cross reference on Rockauto
scroll down and click on related parts
CV Axle Shaft Seal. Drive Axle Shaft Seal - 58mm, Front, Rear. | FordUS
This seems to be the right one, but I will do some more research before I ship it all the way to Germany and start ripping stuff apart.
No worries i think i may have it. im still open to help if anyone does have it though lol.
I guess you'll be bringing it home? :)
I was about 16, went over to Mississippi over a little lady I met in Texas. Working at a Billups gas station.
Some guy pulled in with a 57 Chevy with the tail fins. I had looked in all the ordinary places without finding where to fill it.
There might have been tail lights in the fins, but also a place that flipped out to the gas cap.
As I filled the tank I noticed the license plate said Hawaii ! He was military and had it flown to the mainland
I will not be. I am an Army reservist and a DAC working at a small Army heliport. but my plan is to stay here after my Gov service limit is reached. The ol ranger will be my little splice of America until it is no longer able to drive. Then I will get a Wildtrack, Thunder, or a Raptor, unless Ford drops a hybrid Ranger in '24.
I found them. it is an axle seal and an intermediate shaft seal and that is why it wasn't coming up.
Drivetrain: Differential Seal
TIMKEN SL260013 1.750 in. Shaft Size; 2.874 in. Bore; 2.874 in. Outer Diam; 0.413 in. Width Info
Front; 4WD; Dana/Spicer 35 Axle
Drivetrain: Axle Intermediate Shaft Seal
TIMKEN 710428 Info
Front; 4WD; Right Hand
