Junk Collector
⭐Supporting Member
Truck of Month
Has anybody actually done the 2.9 harness mod where you splice in two more injector plugs for use with a V8?
It sounds a little ghetto but insanely tempting - I am using a speed density 5.0 engine from an '89 Crown Vic, the injectors on those are bank fired, right? So adding one more on each bank doesn't seem like it would be an issue at all.
The 'Vic had two O2 sensors - would that pose a problem? Is it necessary to have two, or would one right after the y-pipe like on a 2.9 work?
I'm assuming this all uses the 2.9 computer?
Let me know if this is really stupid, but in my head it seems like it will work and I've heard the rumors. I am trying to avoid using the 5.0 harness because I'm having a hard time finding wiring diagrams to splice it into my truck.
