Frame Swap
alyssasdaddy
Upland, California (91786)
Has anyone done a frame swap on a 2002 ranger?
Is there anything that i should be aware of?
Can someone direct me to chassis torque specs?
Will a 99 - 2000 frame work under my truck which is a 2002?
March i will be swapping my frame out because of frame damage, I will take the pictures and show what i went through.
If this is in the wrong forum to post in mods please direct it to the right forum..
March is when i start with this whole experience.
I saw someone on here say that you could put an 83 body on a 2010 frame, as long as they have the same body options. The biggest thing to watch for is that your donor matches your cab/bed configuration.
Oh i am positive that you can put an old cab on a new frame, but I am starting from a frame with nothing on it and swapping my suspension, drivetrain, cab, bed and all over. Mainly the question is will my 02 suspension fit the 99 - 2000 frame?
I can find 99-2000 frames all day long but late 2001 up hard to come by.
FYI I have done a few frame swaps and you won't have any problems, just alot of work. The truck I am driving is a 2000 and I put it on a 2004 edge frame then recently converted it to 4wd.
I know a guy that can do a full frame swap in under 12 hours. He is ridiculous though.
I would quote the last two but I am posting from my phone, anyways I am not looking forward to the swap but it needs to be done. I do realize it is going to take most of my time for two or three days prefer two. I just don't want to pay the 500 for the frame pulls, I am getting a frame for 200 and its my friend and I that are doing the labor.
For the guy that can do it in 12 hours where is he I need him here. Well at least that gives me hope I will time myself during the swap and give my time on thhe experience. At least I get some new tools for the job. Battery powered impact, and a new socket set from good ol sears.
Thanks for all responses it is greatly appreciated.
HAHA, Greeny ain't exactly the "help a guy out" kind of guy.
Think AllanD's level of technical knowledge wrapped in a jaded, anti-social 50 something old man who is always in pain.
Worked with the guy for 2.5 years, if he wasn't pissed about something you couldn't get 2 words in a row outta the guy.
My last frame swap, a few pics...
The two trucks...a rolled 4wd 2000 (white) and a 1999 2wd body(Gold)
Frame Swap
Frame Swap
Frame Swap
Frame Swap
Frame Swap
Frame Swap
Its really not that hard. Unhook everything under the hood that connects the bod to the motor Wiring harness, a/c lines, radiator, ps pump ect. (don't forget the ground wire by the brake booster to the back of the head) steering column, e brake cable, wiring harness underneath the ds seat(by trans) ground to the frame under ps rocker. 6 18mm cab bolts(heat is your friend)
Sorry I have not responded to your replies, I am posting from my phone and so far it has not failed everytime I have something written I hit the back button on my phone. So thanks for all your responses. Its is greatly appreciated.
