So from what I just read and understand. If I hook the ported vacuum to the main vacuum on the intake and take the hose from the intake main vacuum hook it up to the distributor it will function the way it is suppose to.
I have a question on the timing I just found out my pistons are 40 over. Because they are 40 over does that change the timing?
40 over raises compression and 87octane can get pingy as compression goes up so you need more advance on the spark to ignite it before compression does, but only if it gets pingy.
Not sure I understand the first part.
If you want to go fast use intake vacuum
If you want better fuel economy used ported.
If you want both get an older ford dual vacuum device: https://www.428cobrajet.org/id-dist-vac-valve
Or this: http://www.allpar.com/fix/engines/cap-valve.html
