Flashlight mounted to seat mountng bolts.
RockRanger
Fresno CA
I was tired of never being able to find my flash light in my truck. So I drew this bracket in CAD and cut it on my plasma table. A few bends and small welds to give it strength and it was ready. I removed the front two bolts that hold the drivers seat and then inserted the bracket and the reinstalled the bolts.
Flashlight mounted to seat mountng bolts.20150330_151034 by Matthew Dresselhaus, on Flickr
Flashlight mounted to seat mountng bolts.20150330_151550 by Matthew Dresselhaus, on Flickr
I have a D cell maglight so I ordered the proper mounting brackets from amazon. http://www.amazon.com/gp/product/B00002N9ER?tag=959media-20 Then I used self taping screws to mount these to the bracket I made.
Flashlight mounted to seat mountng bolts.20150611_152850 by Matthew Dresselhaus, on Flickr
Here it is with the flashlight in place. It is easily removed while sitting in the seat or pulled out if I am outside of the truck. It is also easy to put back for the next time it is needed.
Flashlight mounted to seat mountng bolts.20150611_125830 by Matthew Dresselhaus, on Flickr
Great idea!!! :icon_thumby::icon_thumby::icon_thumby:
That's brilliant.
You should make a bunch and market them here. I know I'd buy a set.
I can make more and sell them. I sent you a PM Ranger Dave.
Did these get made and sold? If not diss the original poster mind if I do my own take on the same bracket idea?
Sent from my SM-N900R4 using Tapatalk
I have an extra pair ready to go. I have an ad in the forsale section for them. Send me a pm for more info.
Sent from my SM-G920V using Tapatalk
Have my driver's side drilled for the brackets for the mag lite, painted, and even installed... no pictures though. Thanks!
It looks like it would be good for a fire extinguisher too.
Indeed!
Have my driver's side drooled for the brackets for the mag lite, painted, and even installed... no pictures though. Thanks!
They got there quick. Lets see some pictures when you get them mounted.
Like this?
Flashlight mounted to seat mountng bolts.20150831_150902 by Matthew Dresselhaus, on Flickr
The plastic strap that came with this model didn't hold well on its side and was easy for the passenger to kick open. Working on finding a better mount to put the fire extinguisher in. Right now I have one mounted on my exo cage just behind the driver.
Flashlight mounted to seat mountng bolts.20150509_135339 by Matthew Dresselhaus, on Flickr
Flip the mount over so he kicks it shut?
Sent from my XT1032 using Tapatalk
Thought about that but want to keep the head mounted towards the center so it is less likely to get hit or damaged.
Is the plastic all one piece or can you just flip the strap?
Edit: just bought the same extinguisher... strap is part of the bracket and not reversible without making modifications
Man I need to pull the seat out, wire wheel the bracket and paint it...
Taken from the bottom to show the room to work
