Fit 33s on 2wd Ranger
ajune93
10+ Year Member
Hey all, I'm new to the forum but need some help with tire fitment. I have a 1996 Ford Ranger XLT 2wd. I am wanting to fit BF Goodrich 33x12.50r15 on 15x10 Cragar soft 8s on my truck. I have already completed a 4 inch lift and from what I've researched I might need to do some fender trimming. I was hoping that somebody could tell me for sure what I'm gettin into.
Thanks
It's quite possible you'll need to trim.
You might be able to avoid it with the right wheel offset, though I couldn't say for sure (15x10" wheels with a 4.5" backspacing would have a greater chance of fitting the tires without trimming than 15x10s with the more common 3.75" backspace).
Another option would be to use a 2" body lift on top of your 4" suspension lift. This would get you the same wheel well clearance as a 4x4 truck has.
Hope that helps.
Welcome to TRS. :beer:
Thanks! I believe they will have 4 inch backspacing and a -38mm offset. Do you know of any good places to get a 2 inch body lift?
The rear end wont be an issue at all. In stock form you can fit 33" tires on the rear.
The front end is what you need to worry about. If you have already lifted the entire truck 4" then you should be set as far as up and down travel of the tire. Turning is the next issue. With 12.50 wide tires and a -38mm offset on a 15x10 wheel you should see no problem turning lock to lock. The bumper itself may be the only thing you need to trim an inch or two off once you have the tires on.
Performance Accessories has a 2 in body lift. I think its for the 93-94 trucks but I think (and don't quote me on this) you can use it on the 95-97. I'd download the instructions to check parts lists and install instructions to see if there are differences.
Sent from my SAMSUNG-SGH-T989 using Tapatalk 2
Ok thanks a lot guys. I will post up how they fit and some final pictures soon
Well the tires are on, they are close, but no actual fender trimming was nessary. however i did have to go at the bumper with a grinder but not too much. Now my only issue is that a full lock i have slight rub on my sway bar, i did install drop brackets for the sway bar with my lift. is there anyway to prevent the rub? I have heard that some just take it off, what are the disadvantages of doing this?
youll just notice the truck dips a little more into corners than it used to. Its not a huge difference. Sway bars are for body roll in corners. They are more for cars or fast vehicles, not trucks.
So would it be more beneficial to actually have no sway bar for offroad purposes?
