Changing my fluid and filter for the first time. I've never changed a transmission filter, anything I should know before I get started?
95' 4x4 automatic (4R44E)
So should the bolts be *snug* with a socket wrench? Or should you make it snug and give a good push, like with lugs on a tire? I don't wanna have to but another gasket and fluid if I mess up lol, filter kit is $22 and fluid is $110.
Torqued to 24-28 in-lbs IIRC, and his trans requires merc 5, but it shouldn't be that much as you should only need about 4 quarts on a filter change...
SVT
Thanks for the advice guys, a few people over the internet gave me more helpful info than the supposed technicians who sold me the fluid.
That was a pain in the ass to say the least lol...
I bought a 10 qt jug of AMSOIL Synthetic ATF... The guys at NAPA said that's how much I needed for a transmission fluid change..... They neglected to tell me that only about 4-5 quarts drains out..... So I'm stuck with $60 worth of tranny fluid!
But a few things I want to add for those that haven't done a change before...
Loosen all the bolts, use a screw driver or something to pry down the rear of the pan to break the seal.... fluid goes EVERYWHERE! When pulling the pan off, DON'T HIT THE ELECTRICAL SYSTEM ON THE DRIVERS SIDE OF THE TRANSMISSION!!!
When changing the filter, have your bucket ready because once you pull it off, fluid drains out the two holes plus be easy with the old filter because it is still full of fluid and drips all over the place lol...
Don't forget to slip on the two O-rings onto your new filter, push it snuggly into place and bolt it down.
And wipe down the inside of the pan vigorously, including the magnet strip on the passengers side of the pan.
I found it easy installing the pan with the new gasket by putting the screws in the four corners and barely tightening them by hand.
And be extremely patient when refilling the fluid... I didn't let it heat up enough or just wasn't paying attention and over filled mine by a quart... and their being no drain plug, I had to loosen all the bolts... again... and drain out about a quart of perfectly wasted fluid. When you pull the dipstick out to check the fluid level, one side of the stick will be covered more because of residual fluid being pulled up with the stick. So go by the "level" line on the less covered side.
That concludes my expereience with the transmission... hopefully I won't have to deal with that SOB again...
Oh and while I was down their, I found out my oil pan is leaking...
I appreciate your concern, but I'm not too worried about my fluid.
I'm guessing I have about 5-6 quarts of AMSOIL in it right now, with a new filter. My truck only has 68k miles on it and the fluid that I drained out didn't look bad at all. I don't have the time or money to go buy another $110 jug of fluid, so I'm just going to let my new filter and clean magnet strip sort out the old stuff. Plus I called the actual AMSOIL customer information line and they said the mixture should run a little better than new mercon fluid. I even asked if I should buy more and drain it again, the guy said I could but he wouldn't because I'll still get more mileage than OEM fluid.
So, overall I'm pleased with my first experience with my transmission.![]()
