I dont have any kind of scan tool though...
That is where the Boost pump is. The truck has 2 fuel pumps, on in tank that is like 3-4PSI and a 30-40PSI boost pump on the frame rail. There is like 3-4 filters on your truck. Mine I know has one on the inside frame rail where it starts to bend up in the front. Right about where the drivers side dash is, but on the inside frame rail. It is a pain in the arse to get to, but it can be done. There might be one(some do, some don't) between the 2 pumps that is a plastic canister style. There is the in tank sock, and another sock at the fuel rail on the engine.The F150 filter probably won't work.
The filter will be on the driverside framerail, right under the drivers seat.
Could you give details? I wouldn't mind checking mine out too.A simple vaccuum test will let you know if you have a clogged cat.
are Ford sending units really that crappy? Mine can be reading empty, and I can usually get in about 34L (9 gal)
