- Aug 6, 2007
- prosperity,SC
- Automatic
When it comes to extending shackles, is the lift height half of the extended length? 4" extended shackles will give 2" of lift. Can someone tell me if this is correct?
Also, has anyone coupled two brake hoses together to make a extended brake hose for the rear? What brake hose did you use for the second hose?
I was thinking of using a brake hose with two of the ends that fit the 3/16" steel line and connecting it to my brake hose with a short steel line.
So I would have the hard line comming from the front, with a 4 or 6" hose, small steel line ( maybe an inch or two), then my normal rear brake hose.
Thank You.
Thank You.
