Extended brake hoses
so is this a direct swap? didnt quite understand what the pics were showing. (i guess im a little slow) lol! thanks guys,im going to pick up lines today.
I did essentially the same thing with a "T" fitting.
so is the t fitting used to get the lines to connect to each other or for length?
so in addition to buying the lines,ill need a t fitting to get these all set up? thanks guys,planning on doing the front end tom.
I did the same thing as well.
And did you forget to hook up your fuel lines? :icon_twisted:
Seeing as how I can see the inside of the bellhousing, i'm gonna take a guess that there was no motor in the truck at the time. :D
