explorer axle swap ranger ebrake cable?
Destroyer000
January 2009 STOTM Winner
MTOTM Winner
Plattsburgh, NY
1999
so i did the explorer axle swap with disc in my 95.. what do i need to do in order to get the factory cables to work with the mini drums?
when i did this swap on my 85' i reused the cables off the 85' - had to relocate them seeing as they were binding on my leafs. fairly simple in my mind. hope this helps.
how did you get them to attach to the "clips" on the caliper bracketS?
I made a new bracket to hold the stock Explorer cables.
To attach it to the forward cable from the pedal I fabbed up some hardware using some of the old clips, nuts and threaded rod (the threaded rod makes for plenty of adjustment as well).
