yeah worse case have to drill and tap for the 2.5 bolt circle(89 down 2.5" circle), but 90+ (3" circle) will bolt up or get the correct u-joint adapter
yeah, just make sure the t-case has the same output flange(or take it with the shaft, easier to setup than a pinion flange), and to comment my above post i don't recommend using any blocks with that setup if your extended cab be a good time to swap in that 98+ shaft
the explorer RAB should be the same, worse case(i think) you just drop you sensor in and it should work
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
