when you guys swap in the explorer 8.8 where do you get the new spring seats for 3.25 axle tube? or do you cut the stock ones off real carefully and reuse them?
i would prefer new, but every 4x4 shop i call or see on the internet say they dont have anything bigger then 3", im about to get 3" ones and get the grinder out lol.
I've got a question related to the 31 spline. Sorry for threadjacking. When doing this swap are you guys fabbing your own shock mounts or are there places to get some?
The exploder 8.8 i got had a nifty towing package. The shocks mounted on the leaf spring retainer plate dealy. (**** technical terms)
I ended up fabbing some shock mounts by taking some 1.5" square tube, cutting it down to two 4.5" chunks. I then drilled a whole through one side and ran a 4.5" long 7/16th bolt through. I then used the handy dandy grinder to grind the other end to meet the curves of the axle tube and burned it home. Red neck as hell but it gets the job done. A hell of a lot better then trying to use some hacked off OE shock mounts.
Edit: You can also use square tube for perches. The article can be found in the tech lybarry.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
