exp rear end
wr250rdr
15+ Year Member
Las Vegas
will a 1st or 2nd gen 8.8 from an exp bolt up to my 95 2dw ranger? or will i need to do some cutting?
no, yes
exp are set up for a spring under, you need a spring over
check in the tech library or use the search button, there are 1000 threads on this swap
Welding on of BOTH spring mounts and lower shock mounts will be required.
AD
AD
Generally preceded by a lot of cleaning of the areas to be welded.
