escape rims
61corv
Nebraska
Has any tried 15" ford escape wheels on a 2wd?
Are they the same bolt pattern?
If they are the same bolt pattern and would fit, they would stick very far into the wheel well since they are a FWD wheel--positive offset.
Or find a set from a Mustang. You can find take off wheels all over the place. Those would fit a Ranger 2wd and probably look better, too.
bullit mustang^
The split 3-spoke 17-inch GT wheels from a 1994/95 Mustang GT fit and you can use the center caps as well. They fit much better on a 1989-1992 Ranger. They are to inboard on a 2003 Ranger for my liking, but they work without rubbing. They fit better on the 2007 than the 2003.
escape rims
escape rims
look at this website
http://www.therangerstation.com/tech_library/wheel_fitment.html
I use this rims lincoln towncar signature 96-2002 16inch series
escape rims
escape rims
You can fully use this bolt pattern rim with just to see the center hole and good offset Alternatively you can use a back spacing
