engine trying to overheat
runnert
Colorado
I know the temp gage is not a true measure of temperature. Here is the problem. At highway speeds. the needle drops below the "C". But at slower speeds and at stops, the engine is getting hot and the needle kinda rises and falls. I had a leak 6 months ago and put in stop leak and that seemed to fix the problem But now my antifreeze is brown. So I was just going to change it since it had been a few years. When I drained the radiator, only about a 1/2 gallon came out. I guess I expected around 3 gallons to come out.
So any idea on my problem is appreciated. Next I plan to disconnect the lower hose and see how much will drain from the engine.
Thanks,
runnert
You may have a couple of problems. The temp gauge swing could be a bad thermostat. Mine acts that way when it wants a new t'stat.
What prompted you to put the Stopleak in? There's a lot of discussion on here concerning internal and external leaks.
Good luck.
I replaced the tstat. Clutch fan seems ok. I had a leak on the side of the engine - noticed a puddle after driving and the stop leak has fixed it so far. It does concern me that when I drained the coolant that only .5 gal came out. How much coolant does a typical 4.0L hold?
runnert
well sometimes that stop leak can do more harm than good it might stop the leak. put it also could have stopped up a few other things too. i put stop leak in one of my old cars and it stop the leak right along with my radiator. you might want to try to flush you radiator out, to see if that is it.
I have seen that before also. But it was such a slow leak, that I figured I would put it in, stop the leak and then replace the coolant. What I don't understand is that I only got .5 gall out when I drained it. I am going to disconnect the lower hose and see if I get anything out of the engine tonight. Is it possible for the water pump to go out without leaking?
Tell if this is a good plan:
1- drain coolant from the engine
2- flush the radiator
3- remove tstat and flush water through the system - drain out the lower hose
then if I still have a problem:
4- take off water pump and check it.
Is there a way to tell if the water pump is working without taking it off?
runnert
where was your original leak at?
if not seen, may be lower intake manifold coolant flow gaskets
start with a strong cleaner such as Prestone Super radiator cleaner
2 bottles, run for 10 hrs op time to clean block passages
pull radiator and garden hose pressurize it from bottom hose outflow side to reverse flush the radiator. set radiator with inflow tank down. regulate water pressure with faucet to about 30psi which is about max that radiators will safely handle.
remove heater hoses and flush the heater cores separately with max. 30 psi from garden hose
use full hose pressure for block reverse flush thru the tstat opening
best to remove water pump and check for broken vanes, some of the pumps came with plastic impellers, they break. if you replace, get rebuilt with stainless steel impeller, cost more but peace of mind
I would flush out everything. Heater core, radiator, motor. Make sure all your hoses are good and theres no cracks or tears in em. Fill it all back up with just water and let your truck run till the thermostat opens. Check everywere for leaks. Spray down your motor also to help clean it some so it will be easier to chase a leak. Thats what I would do.
I would never believe it if I didn't see it. I took the radiator and had it checked. IN 5 seconds he told me it was fine. I explained the symptoms. He asked was Tstat I had put in. When this all started 6 months ago, I put in a napa tstat. He told to try the Ford Tstat. He only drove ford (he had a late 80's model ranger) and that he saw this same problem with other Fords. So I put in a Ford Tstat and it solved my problem. Appearently, the napa Tstat would open, but only under the pressure of the heat rather than the temp of the water - which would explain the leak probably. So my problem is fixed.
runnert
