Engine problem
Maxwellzer
Seattle, Washington
Three nights ago I acelerated out of 2nd gear and the engine cut out. I Attempted to start the truck for 30 or so minutes to no glory.
Not having any experience with this engine i took it to the Ford dealer. They said the fuel pressure was irregular so in turn asked me if they could replace the fuel pump and a fuel relay. Fixed...i thought.
This morning...driving to the store the truck cut out again...same issue. Turning over...but not firing...after 10 minutes of attempts it started right up.
The question is...What else could be the issue with the engine if they replaced the fuel pump.
-Injectors?
-Any part of the ignition?
Kyle. Thanks a ton. Next time it happens ill Definitely hit that button. Hope thats the problem.
Thanks
