h_f_davidson
- Jun 19, 2024
- Baltimore MD
- 2.8 V6
- Manual
Hi all! I have a 1984 Ranger, 2.8L V6, about 160k miles on it, previously owned. Had it about a year now and for a while it was running steady, but this problem is new—now the engine really struggles to start (cranks fine but doesn’t start?, and when I can get it started it can only hold an idle for about 20 seconds and then just tapers off and dies. I’ve replaced several parts to do with charging/ignition (alternator, starter motor, starter coil, voltage regulator) to fix other issues, and the previous owner says he rebuilt the carburetor. Is this a fuel pressure issue? If so, any advice on how to fix? I’m pretty new to this so still learning! Thank you!
