engine blew...
mo24valve
5+ Year Member
I recently purchased a 1992 4x4 ford ranger 5 speed with the 2.9l and 132k miles, well long story short a week later it lost oil pressure, blew a head gasket and had serious lifter knock, So i purchased a 1991 4x2 auto with 53k miles that i was told had the 4.0l but when i got home and looked a little closer I found it to actually have a 3.0l... I plan to do a engine swap but dont know if the 3.0l will bolt to the 2.9l 5 speed. Any help would be greatly appreciated, I need to get this truck goin ASAP.
Nope. You will need the 3.0 transmission
AJ
Sent from my SM-N910V using Tapatalk
Do they make a adapter plate or could I modify the autos bellhousing to work? I did some Google research and saw people swaped fm146 transmissions with m50d's so im kinda confused.
take the 3.0 back and get a 4.0l or 2.9l
What would i need to do to make a 4.0l work? Computer, wireing harness?
Same trans, etc. Why bother sticking to a 2.9?
because the 4.0 will rip that 2.9 trans up after a wile.
but you are lucky you don't have a new enough truck you don't have to swap the dash out... i just got a 91 4.0 to swap into my 88 ranger then found out i have to swap dash and all :bawling: so now i have to sell both as parts as I'm so dang fed up not funny....
best of luck!
Is there any way to make the 2.9l distributor work on a 4.0l?
best of luck!
Why wont the 2.9l transmission hold up?
4.0 is a distributor less engine
Sent from my Samsung Galaxy Note 4 while sitting in my underwear
Im missing the wiring for the coil pack so i was going to try and make the distributor work
