I have a plan but thought I would run it by everyone first to see if I am missing anything or if there is an alternative... I bought a salvage titled Ranger with a host of problems to work on last winter; my project and the idea was to use this to pull my small boat trailer instead of using my Chevy work truck.... I was told that the shift lever was goofy by the gal who owned it and if it didn't start when I turned the key, to push the shift lever up into "P" a little firmer and it would work (neutral safety)... and that was an accurate statement. My concern was backing down the ramp at the lake with my boat trailer and getting out to launch/retrieve the boat.... would the Ranger stay in park? If I shut it off, would it stay in park? But to be sure, I wanted to be able to use the emergency/parking brake... I talked to the former owner and she said they never used it... ever... I know from experience over many years not to mess with E brakes if they have not been used.... they get stuck on and you are screwed.... So I talked to a local trusted mechanic about it and he said NOT to try it but bring it in and he would put it on the hoist, pull the back wheels and hubs, and then try it.... which I might still do but he, like everyone else, is swamped.... So I thought I really don't need a hoist and this is not rocket science... so why not jack up the rear, put it on jack stands, pull the rear wheels and hubs myself, and then follow his suggestion about pushing on the E brake one "notch" and releasing it... to see what happens... then repeat... pushing the E brake on two notches and releasing it... In other words, working it a little bit at a time.... and see what happens... If it does lock up and won't release, then the thinking is simply cutting the E brake wire at the wheel which would wreck the E brake and it would have to be replaced but at least, I could still put it back together and use it.... Does this sound plausible? Am I missing anything here? Has anybody replaced the cable/sheathe? Does the E brake sheath/cable go to a yoke in the middle? I am hoping I am being a little paranoid on this and I am hoping to just get lucky and the E brake works fine..... but I don't want to find out the hard way.... Ideas and suggestions welcome..... Have I got this thinking right?
