Electrical problem! I need help!
Yeah, you could try to run codes to see if any are stored in your system. Your system is non-OBDII, unlike mine so I'm not too familiar with it but if you do have codes you can post them up here at TRS and someone will know where to start.
The same place you bought the wires at should be able to loan you the code reader for free. You may have to pay up front for it but when you return it you'll get your money back.
Allen
I have the truck at an electrical shop. They can't get any codes out of it. They said its running perfect as of now. That happens every time. I don't have to pay if they don't find a problem, thank god. I just hope they're patient, so the problem will be present. It was driving rough as can be all the way there and they even said it was rough to pull it into the garage. Now it's the perfect little truck..... Every time.
Turns out my PCM wasn't getting a proper ground. So the shop is grounding it and only charging me for the initial service inspection.
That ground was effecting my CPS and another sensor.
Intermittent problems are the absolute worse.
Thanks for all your help! much appreciated!
I'm so glad you got it buddy!
Let us know if that fixed it!
Allen
I should be getting her back tomorrow, 2-20-08!
I'll post then.
Thanks again! I'll be on here more often, hopefully with less problems!
The shop called, Afetr grounding the PCM and realized the PCM has shorted itself out. So they're replacing it. And my CPS has gone bad as well......
So the final repair was a new PCM and a new CPS.
Thanks again for all the help guys.
