Electrical/mechanical PLEASE HELP
1994xlt
Forum Member
Morton
IL - USA
Vehicle
Drive
Stock
Stock
good question
Hey yall, so I well I guess I really don’t know what the hell is going on, but yesterday my truck stalled out while decelerating and again it did it twice it’s always when I’m decelerating. The power steering goes stiff and I lose all power or atleast my radio goes out for 3-5 seconds and in thoese seconds my truck doesent turn over with the key at all, but then after 3-5 second the radio comes back and I still have to turn the key 3 more times or so for it to finnaly crank over again, well I had my dad with me this time because I wanted him see tho happening and keep in mind it’s not every time i decelerate it’s only when it wants too well so I got to the place I wanted to go and turned the truck off and got back in turned it on and made it idk 70-80 feet back into the main road and all of a sudden I hear a grinding noise and get out well my starter is cranking the engine while the engine is running even with the key out of it. Well it took us a bit but we finally got it. To stop and we got it home somehow idk how really and so we replaced the fender starter solenoid and the ignition switch and the second i turned the key the starter just kept going and going and going if you all need more specific info let me know I don’t really know what to do I hope my engines not messed up because the starter ran for 15 mins or so with it running
Can you post a pic of the fender solenoid? The battery side big terminal gets all the wires EXCEPT the starter wire, which goes on the other side big terminal. The small terminal should get power only when the key is all the way turned to start. Use a multimeter and test the small wire to confirm.
My
my solenoid wires have a rubber piece were it forces wires 2 wires to go on the solinod one on each side so 3 wires go on one side and just one wire on another side
This is a 1994 ford ranger with the 4.0
Not seeing much responses anybody experienced something like I have I don’t really know what to do
Sure sounds like you're having issues with the ignition switch. At least with the continuous cranking.
I would disconnect the start wire from the starter relay... then try to use a jumper to make it crank... and stops when you remove the jumper.
Ok well I did replace the ignition switch though could it still be bad
What all did you replace? There is the key cylinder, the electrical part of the switch, a rod, and there has to be at least one spring in there somewhere.
The electrical part but I put a new starter in now and it’s working ok but today it kinda had a lope idle I noticed but the gauge never moved it revved up and down enough to when I was idling thru a parking lot it was jerky
Have you looked over the wiring harness? I would check for damage, especially for any spots that may have rubbed through the loom/insulation.
Might have nothing to do with your issues but it kind of has the feel of something grounding out that shouldn't or something intermittent causing the computer to freak out.
Any other weird electrical symptoms?
@1994xlt
This is a shot of the fender mounted solenoid on my 94 4.0L Yours should look like this:
