I'm a little late, but I am impressed with the discussion. I'm slowly building a saturn EV conversion at the moment and I am an electric car nut.
Some numbers to throw at you:
The average PEAK net efficiency of a gasoline vehicle is about 22-25%
Diesel or hybrid could push closer to 30%.
Real world averages are lower.
50% efficiency is what you get from the 3 story high 2 stroke diesel container ship engines that redline below 1000 RPM. And thats at the crank shaft, not the propeller.
Electric motors can vary in efficiency depending on the type and build quality.
Brushed motors are usually at around 90% efficiency, but it gets lower the more you load them and torque bleeds off at higher RPM. On average, 80% is not unreasonable even for the better motors like ADC and netgain (most popular for EV conversions).
Brushless motors are a different animal. If designed right, their efficiency and torque holds higher much more steady across the operating range. 96% peak efficiency is possible and average above 90%. Their power is only limited by heat.
A well designed electric vehicle with a brushless motor and lithium battery can get close to 90% peak efficiency if you can get the better tech in it. Cost is the problem.
If you are using lead acid batteries and a brushed motor, 50% efficiency can happen simply because of the horrible voltage sag from the batteries (driving with a light foot helps). Its still twice as efficient as a gas car though.
