- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- few inches
- Tire Size
- ~30"
Anyone here got experience with electric automotive AC compressors? How do they work, how much power do they need, etc?
Not actually asking for a ranger, but I figure it's kind of universal and could be applied to a Ranger as well. I'm wanting to add AC to my 68 F-100, it stays parked for a lot of the year due to lack of this creature comfort. Simply too hot here much of the year to want to go with out it. Unfortunately, the engine is not setup for AC and is not a super common engine these days. From piecing together (dual belt alternator) and fixing other things I know that this FE does not exactly have a factory accessory drive configuration, so I'd have to mix and match parts until I figured out what works. That's a headache I don't want to get into.
Down the road I intend to either rebuild this engine and install a serpentine drive kit or do an engine swap, but that's quite a ways off. I haven't decided on which I'm going to do yet and I'm not sinking the money into a high dollar conversion kit until I know. I don't want to wait that long to get an AC installed.
One thing that this truck does have is a lot of open real estate under the hood. It's also been converted to a gen 3 alternator which is already higher amperage than original and could be swapped for bigger pretty easily. Since I'm undecided on the engine, I'm thinking why not use a compressor that can be used with any engine. Electric driven compressors must be getting more common considering the amount of EVs that are being built and developed. Actually 12v compressors are becoming more common in campers and RVs too, so they must be getting some decent tech behind them. Build a system that uses the 12v compressor, but is otherwise the same as regular system, then when the engine work is done down the road I can convert to an engine driven compressor if that makes more sense then.
Of not, thanks to that extra underhgood space, I also have room for a second battery. That might help with providing needed amperage for the electric compressor. I was already figuring on adding a second battery for the Warn 8274. Honestly, I don't expect to ever use the winch, but its been on there for 30+ years (unwired and without cable) so it's kind of part of the truck. Since it's staying on the truck is is going to be functional.
If I figure out that this works it might also end up on the 85 Ranger. I intend to do a 2.3 turbo build and the turbo might want to occoupy the same area as the AC compressor. If that's the case an e-compressor might be a good alternative for keeping AC.
