EGR Upper Intake Manifold Tube Source?
97 Ranger STX
Alexandria, VA
1.5"
Stock
33x10.5x15
Hello TRS. Anyone know a good source for the EGR tube that attaches at the upper intake manifold? Mine has a crack at the connection on the lower end. Can't find one anywhere; all the sites just show it as "discontinued" and not available. The part number is F87Z-9E470-AA. I know many junkyards might have it but would prefer a younger replacement. Looks like this:
I have the same problem , repair shop said the egr pipe going into the manifold is rusted and there is a hole in it , can't find the pipe(tube) anywhere. is there heat tape or something that could fix the hole that could work? according to repair shop extensive work to get rusted pipe off (to possibly have one made) and not sure that something else might get damaged in the process.
I have seen JB Weld hold up to exhaust heat back in the exhaust pipe system. Maybe it would hold up on the EGR tube.
Maybe a combination of a layer of JB Weld, then wrap it with thin aluminum and use a couple of hose clamps to squeeze it together. Don't expect the shop to do this though, most shops won't freely admit to rigging stuff, though they do it on the sly all the time without telling you.
On the Mustang I had, that pipe had fitting that connected to some high silicon content rubber hoses for the DPFE sensor. I wonder if some of that hose with a few hose clamps would work? Of course you'd have to split it lengthwise to get it on there.
