EGR tube
Speedwagon
Having a hard time finding an EGR tube in the junkyard from another '87ish 2.3 Ranger. But there are alot of Mustangs in the junkyard of various years with the 2.3. What other years/vehicles can I get an EGR tube from? Mine is bent at the end, causing a leak, and Ford says the part is no longer available. Or other suggestions?
If yours is bent and not broke all the way through, and still has flow going through it. Just braze the hole shut. Since the part doesn't move or have any moving parts that will be a sufficient fix for your problem.
I would try to use air injection hose. It looks like heater hose but can withstand great amounts of heat.
