- Sep 22, 2007
- Michigan
- 2.9 V6
- Manual
- My credo
- A legend to the old man, a hero to the child...
86 BII 2.9
Im battleing an issue where during acceleration it basically "flatspots"...athough i do feel a bit of missfiring too.
Does it worse when warm.
I had code 31 and 84 KOEO. I cant get it to communicate on a KOER for some reason.
Anyways...i pulled the EGR valve...passage was not blocked, either was the tube. Valve is opening and closing.
Im getting 12v to the vacuum solenoid, however, i dont believe its getting a signal to open the valve. I know the ECM grounds it to open it. I took a spare wire and stuck it on the ground side and while engine running could hold it to negative battery post and open/close valve at will.
However....i could get no vacuum from the solenoid on my vacuum gauge regardless of RPM...i also hooked the ground of my test light to the ground wire and held it to hot, it never blinked on.
So is it safe to say the issue is either with the yellow ground wire or ECM?
I did have the egr sensor unplugged during this test...not sure if that would of mattered.
I had a new feedback sensor laying around so i swapped it out. It did seem to have more power and code 31 went away.
Any advice?
BTW...i did check fuel pressure while warm to make sure the pump wasnt screwy...it was 38 on prime, 32 running, and would spike to 42 if i jammed throttle, but quickly returned to 32. So i dont think fuel is the issue.
The EGR pipe is intact well and everything seems to be working. So i hate to dump an 88+ ECM in it if its just a wire. Just not sure how to test the wire.
Any advice?
