- Jun 23, 2008
- Manual
Hey I have an 85 b2 that I did a 2.3 swap and duraspark on. I know this is the 2.8 forum but you guys are always talking about duraspark. It ran good for about a month. Then i went to start it and no spark. I did leave the ignition in the on position as it doesn't take a key it's easy to forget to push the button on the column in to take it to the lock position. I checked all of my connections and grounds they all test ok. I changed out to my spare ignition and got a weak spark at the end the coil wire to the distributor. Didn't sound like the engine was firing though. I checked my cap/rotor and fried my other module, ignition in the on position. Is this normal? I have never had to put something in acc. or off like that. Any help would be apreciated.
