Are there any simple/easy ways to boost power on my 2002 4.0?
Supercharge it.
Always drive with the wind behind you.
TRS decals.
Before adding the complication of performance mods,...simple/easy ways to boost power on my 2002 4.0?
Hmm. Is there anything you can keep?Before adding the complication of performance mods,
be sure you've first taken care of notorious failure items inherent to your 19yr old V6~4.0L~SOHC:
~ Become OCD About Oil+Filter Changes
~ Replace OilPressurized TimingTensioners
~ Replace Plastic ThermoStat Housing with Alum ThermoStat Housing
~ Replace PlasticTanked 1CoreRadiator with AllAlum 2\3\4CoreRadiator
~ Replace Plastic HeaterControlValve with AllMetal HeaterControlValve
~ Replace Coolant Hoses\Clamps\Pump\Fan+Clutch, Flush+ReFill
~ Replace Ignition CoilPack+Wires+Plugs + Exhaust OxygenSensors
~ Clean\Replace AirFilter\MAFSensor\ThrottleBody\IACValve\EGRValve+DPFESensor+Tube\VacuumHoses\PCVValve+Hoses
~ 5r55e Tranny ATF+Filter Change; Consider Rebuilding ValveBody, Additional GrilleTrannyCooler, Replacing ColumnShiftOverDriveButton
~ 1354 TransferCase ATF Change; Consider Replacing\Spare ControlModule+ShiftMotor
~ Change Differential Fluid
~ Service Brakes+Fluid
~ Service Suspension+Tires
~ Replace InstrumentClusterBulbs+DashCenterPanelBulbs
Instructions: Throw used truck away, buy new truck.Hmm. Is there anything you can keep?
