- Jul 17, 2009
- Automatic
Well,have started another round of truck maintnance,which with this 87 Ranger is actually "rebuild" or "restore" or "alot more than I expected to spend!" In this case am redoing the brakes starting in the rear.Problem #1 is the e-brake gets stuck once depressed.With the rear brakes disassembled I can find no sticking,etc..Question
o the springs on the e-brake cable (located where the cable plugs into the brake backing plate) supply all the spring pressure on that cable,or is there another spring somewhere?Problem #2:There are some deep grooves on the bottom brake shoe lands in the backing plate.I have ground them smooth so the shoes will move freely but am wondering - with all the metal I had to remove,will this cause the shoes to misalign and contact the edge of the shoes before they make full contact?
